38 Users Online (37 Members):
Forums >> Revit Structure >> Technical Support >> Callout on a framing elevation
5 Posts No Rating |
I created a framing elevation for a specific column line with bracing and it looks great. Shows everything the way I want. When I open the callout detail the beams and column are now hatched. I guess this is from the framing elevation being cut on the column line which is also the center line of my beam. It's cutting through the web of the beams and column and showing it hatched as such. I want to be able to see the flanges of the beams and column just like in the framing elevation.
Is the detail level set to "Coarse" in your callout? A coarse hatch could be overriding your desired view graphics.
5 Posts No Rating |
Both the framing elevation and the callout detail are set to fine.
Look in your HELP for cuttable families. The structural elements are cuttable so move your section.
6 Posts No Rating |
Hello, I'v tried someting that might help. Go to the properties of the beam. Go see if the material is set to steel. Then go see if a hatch patern is set to something, if so, set it to "noting". Hope it is the solution, :-) Bye see attachement in french :-(
Structural Framing Plans/Callout Beam Sizes |
Wed, Feb 22, 2006 at 5:49:10 PM
Framing elevation to section |
Fri, Jun 13, 2008 at 2:54:41 PM
Phases and Elevation or Callout Marks |
Sat, Sep 26, 2009 at 8:49:53 AM
Elevation Callout loading, but can't be used |
Wed, Jul 28, 2010 at 12:48:03 PM
Elevation markers & callout plans |
Tue, Jan 28, 2014 at 10:08:45 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
