66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Web Update for Revit
Sat, Oct 3, 2009 at 5:30:18 AM | Web Update for Revit
4 Stars: 202 Votes
The new Web Update for all versions of Revit (20090917_1515)
Architecture - http://www.autodesk.com/revitarchitecture-download
Strutcture - http://www.autodesk.com/revitstructure-downloads
MEP - http://www.autodesk.com/revitmep-download
Update Enhancement List: - http://images.autodesk.com/adsk/files/rac2010_update2_list.pdf
 Annotation objects no longer disappear when panning a view that spans two monitors.
 Improves stability when switching between Autodesk Revit Architecture 2010 software and GoogleEarth™ software.
 Improves the modification behavior of hosted sweeps (i.e. gutters) attached to joined roofs.
 Improves stability and performance when modifying walls.
 Improvements to shared nested families.
 Improves stability when modifying masses.
 Improves design option rules adherence for walls in different design options and worksets .
 Family and type information can now be read in Autodesk® 3ds Max® software from an FBX® fileexported from a non-English version of Autodesk Revit Architecture 2010.
 Improves stability when adding views to sheets.
 Improves stability when making a design option primary.
 Improves stability of printing views in wireframe mode.
 Shadows will no longer be cropped when a view is printed or exported to a DWF™ file.
 Subscription notifications are now available from InfoCenter.
 Improves stability when reading IFC files.
 Improves stability when opening a project with an inserted TIF image and when importing a TIF image.
 ViewCube® navigation tool and the navigation bar will now display correctly after unlocking thecomputer.
 Improves stability when removing panels from the ribbon.
 Improves stability when cancelling a move, delete or copy command.
 Improves performance of view renaming and the Workset dialog.
 Mass floor schedules will now update when a level is renamed.
 A form element that has a divided surface applied to it will now be correctly generated after a copy,paste, or move.
 Improves stability when exporting to DWG.
 Dimension and spot elevation values will now display correctly in a dependent view.Autodesk® Revit® API 2010 Enhancements.
 Improves stability when subscribed to a DocumentOpened event.
Edited on: Sat, Oct 3, 2009 at 5:33:25 AM
Revit Web Update #3
Wed, Nov 21, 2007 at 1:40:23 PM
Web Update 1
Sun, Jun 29, 2008 at 1:47:58 AM
Revit 2009 Web Library
Wed, May 21, 2008 at 4:13:54 PM
Glass shows thru all other objects
Tue, Apr 1, 2014 at 2:33:31 PM
UPDATE 1
Tue, Dec 4, 2012 at 8:21:13 PM
Page generation time: 3.9330
