Forums >> Revit Building >> Technical Support >> Exporting a rvt file to Sketchup; Saving a 2009 file to 2008
Sat, Oct 3, 2009 at 5:16:02 AM | Exporting a rvt file to Sketchup; Saving a 2009 file to 2008
Beetle
Is there any way to export a revit file/model into Sketchup- I've tried "Export" and "Save as" as get no options for Sketchup?
Likewise,I need to send my 2009 model to my graphic consultant in 2008 format, but can't get any option to do so.
I'm probably missing something totally obvious- the one thing I know about this incredible software is that if it doesn't work it's because I'm not doing it properly!
Sat, Oct 3, 2009 at 7:37:31 AM | Exporting a rvt file to Sketchup; Saving a 2009 file to 2008
tim123
4 Stars: 19 Votes
Export the Revit file as a DWG.  You can then import it into Sketchup.
You cannot save a 2009 model in 2008 format.  Your consultant will need to upgrade.
Sat, Oct 3, 2009 at 12:53:39 PM | Exporting a rvt file to Sketchup; Saving a 2009 file to 2008
Beetle
Thanks Tim123- I'll give it a try.
Revit 2009 file size DOUBLE 2008!?!?
Thu, Jul 17, 2008 at 11:34:24 PM
Open 2009 Files in 2008
Mon, Aug 4, 2008 at 1:10:04 PM
Opening 2008 file in 2009 causes "Unrecoverable error" crash
Tue, Jul 28, 2009 at 1:36:33 AM
Help! How to save a template file as an rvt file?
Wed, Aug 20, 2008 at 11:27:01 PM
Exporting Revit 2009 (.rvt) to AutoCAD (.dwg)
Mon, Jul 13, 2009 at 3:55:27 PM
Page generation time: 1.6340
