72 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Manage Link
Fri, Oct 2, 2009 at 11:13:48 AM | Manage Link
diesellam
Is there a way you can freeze certain elements in the linked Revit file?  (Like freezing certain layers in the Xref.)
Fri, Oct 2, 2009 at 12:53:03 PM | Manage Link
jhayden
jhayden Avatar
Do you mean freeze them so they aren't visible in the view? If so, then you can go into visibility graphics (VV or VG)and click on the 'Revit Links' tab. Select the linked file and open the 'By Host Settings', select the 'custom' circle, then you can go into model, annotation or import categories and modify the elements you want to see. To 'freeze them', just uncheck the box on the left hand side. If the elements are greyed out, select custom from the drop down box at the top of the window.
Fri, Oct 2, 2009 at 1:37:38 PM | Manage Link
diesellam
Cool.  It works well.  Thanks for the info.  I appreciate it.
This is my 2nd question:
If I link this file (which already has a linked file in it) into another file, whatever I freeze in this file, would they show up in the other file or they remain frozen (like the nested xref)
Fri, Oct 2, 2009 at 2:24:48 PM | Manage Link
jhayden
jhayden Avatar
I'm not sure on whether they would appear or not. My best guess would be that they will appear. When you go into VG and adjust the settings to show certain elements, it only applies for that view, not the entire model.
CAD inserts appear in as many copies in my manage link view
Fri, May 15, 2020 at 5:17:44 PM
import/link, manage links...
Tue, Apr 1, 2008 at 11:46:16 AM
Manage Revit Link
Fri, Jan 8, 2021 at 10:44:38 AM
Manage Link - Reload From MULTIPLE FILES !
Tue, Dec 8, 2009 at 3:36:08 PM
Revit Link Visibility Graphics
Sun, Mar 6, 2011 at 10:22:08 AM
Page generation time: 0.5586
