117 Users Online (116 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Railing without extension
Fri, Oct 2, 2009 at 10:37:26 AM | Railing without extension
elduderino1234
I am trying to create a short rail with no extensions on the end. I want it to follow the rise and run of a stair but to not have a flat extension. I have included an image for claity (wall that the rail is attached to is hidden for clarity). Thanks
 Revit 2009
Fri, Oct 2, 2009 at 10:40:53 AM | Railing without extension
All railings are sketched by line segments.  One slope railings should be one line.  Your's has 3 segments to the sketch.  Delete the two end segments and pull the center line out accordingly on each end.
On second look ... you may have added extensions on your rail... take those off because they are always flat. (They are really a post believe it or not)
Edited on: Fri, Oct 2, 2009 at 10:47:30 AM
Fri, Oct 2, 2009 at 10:54:51 AM | Railing without extension
elduderino1234
Ah, I figured it out. Somebody added the extension as a baluster family. Thanks
Stair railing baluster falls short on ADA railing extension
Mon, Feb 8, 2016 at 7:38:53 PM
12" RAILING extension (Image Attached)
Sat, Aug 30, 2008 at 9:53:19 PM
Railing Extension Problem
Mon, Dec 5, 2016 at 12:52:30 PM
Stair railing at extension in Revit 2012
Wed, Feb 1, 2012 at 12:11:11 PM
Handrails Flatten When Extended
Fri, May 29, 2015 at 1:11:11 PM
Page generation time: 2.0526
