94 Users Online (93 Members):
Forums >> Revit Building >> Technical Support >> REVIT export to DWF
4 Posts No Rating |
Hi this is my first time posting and I'm using REVIT Architecture 2010.The problem is that the drawings exported from REVIT to DWF the text style StylusBT which I've applied to the drawings were changed to Arial during exporting.If somebody could shade some light to this problem is very much appreciated.Thank you.
Did you install the "Web update 1 and 2" for 2010?
4 Posts No Rating |
Firstly Thank you Typhoon for your reply.And yes I did apply the updates still it's the same.
Very wierd, like you can see in the image it works fine with me....
4 Posts No Rating |
Hi Typhoon, I've discovered this,while in administrator mode I was able to do so,but when I switch to another user,it just turns out to be bad.Guess I'm suppose to stay in administrator mode then.Thanks again for your kind reply.Really appreciated it.
hummm, "while in administrator mode I was able to do so,but when I switch to another user,it just turns out to be bad" - that i didn't know because i always "enter" by administrator mode but i'm glad you solve the problem.
Revit 2012 - export DWF - corrupt dwf file |
Fri, Aug 3, 2012 at 10:47:11 AM
3D DWF export in Revit 2009 does not export identity data |
Thu, Nov 19, 2009 at 12:01:43 PM
Revit views to DWF format to print |
Fri, Mar 19, 2010 at 12:21:41 PM
help! dwf for 2d plans |
Sun, Feb 26, 2006 at 8:15:57 PM
Help with dwf visible parameters |
Mon, Aug 23, 2010 at 2:41:35 PM
Members: | 2017156 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
