64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Find Objects Associated to a Level
Wed, Sep 30, 2009 at 2:59:54 PM | Find Objects Associated to a Level
jhayden
jhayden Avatar
I have a floor that has to get raised so I changed the elevation of the associated level to the new elevation. Unfortunately, there are other items that are referenced to this floor that need to stay at their current elevation. It's a huge model so trying to find each element would take far to long. Is there a command or an easy way to find what elements are referenced to this level?
Thanks
Jeff
Fri, Oct 9, 2009 at 12:13:32 PM | Find Objects Associated to a Level
emgeeo
3.5 Stars: 7 Votes
Easier to create a new level and associate the floor to that new level.
Re-host elements to that new level as needed.  Use 3D views to ensure quality.
My best recommendation.  You can also apply filters to framing families based on elevation.  That means you can say...all beams (or columns) at or above a certain level display as red.  This will help you see what framing is at what elevation while in a plan view.
Does that help/make sense?
Fri, Oct 9, 2009 at 1:32:03 PM | Find Objects Associated to a Level
emgeeo's suggestion is partially OK.   If this level is important for other reasons, rename it and add the new one but don't "rehost"...instead, just copy from one plan to the new and delete from the old.
Find connected objects to a Level?
Sun, Jan 20, 2013 at 10:45:35 AM
objects from 2nd level appearing in 3rd level why?
Mon, May 20, 2013 at 4:35:42 PM
Move a level without deleting objects on that level
Tue, Jul 4, 2017 at 5:20:24 AM
find elements associated with level (2017)
Fri, Sep 14, 2018 at 6:08:43 AM
Objects constrained to level ...
Wed, Feb 3, 2010 at 6:28:26 PM
Page generation time: 0.6766
