45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Toposurface not connecting contours
Wed, Sep 30, 2009 at 1:49:43 PM | Toposurface not connecting contours
EHidey
Hi,
I am manually picking points along an underlayed CAD file. At the sharp turns in the site, Revit is not following the points that I have plotted and creating plateaus where they do not join (see attached image-the areas I am talking about are in red). How can I get these to connect or is there a setting that needs to be changed to allow them to connect properly?
 Any help would be appreciated.
Thanks
Wed, Sep 30, 2009 at 2:29:43 PM | Toposurface not connecting contours
4 Stars: 203 Votes
Increase the number of points in those areas.....
Wed, Sep 30, 2009 at 2:30:42 PM | Toposurface not connecting contours
REVIT is not meant to do Civil work.... The tools are really just not there.
Topo drawings should be CAD - period.  Any views that need to show the site as contours should use a linked cad file to do this.  But Revit will do a very nice job of modeling the topography for 3D views ...point elevations and for you to show the topgraphy against the structure in sections and elevations.
The best way to do your Revit site model is to have or create a CAD dWG with contours as 3D polylinesset at the proper elevcation and you import this CAD DWG to create your model.
Toposurface Contours
Mon, Aug 25, 2008 at 4:47:22 PM
Revit toposurface detail level
Fri, Feb 11, 2011 at 3:06:54 PM
Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing
Wed, Aug 31, 2011 at 5:29:12 PM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface-Extra lines that shouldn't be there. Image included
Sun, Feb 20, 2011 at 10:49:51 PM
Page generation time: 0.2963
