40 Users Online (39 Members):
Forums >> Revit Building >> Technical Support >> Roofs
Hi all, how to shorten certain [top layer] compaired to other layers of my roof. Like with walls its possible to modify "vertical structure layers] I need to end the rooftiles before it encounters the wall, and don't prefer to work with void, inplace families. GrC
You can do it as two separate roofs. I typically just have the roof as the tile and batten layer and then a separate, joined roof to include the insulation and rafters. Depending on the roof, you could do the structure independantly, using a beam system or array of trusses.
joining roofs |
Mon, Jan 9, 2006 at 1:20:09 PM
Intersecting roofs |
Mon, Oct 16, 2006 at 8:28:41 AM
Problems joining roofs |
Fri, Apr 16, 2010 at 10:52:16 AM
Revit 2008 Multiple Roofs on Same level? |
Tue, Jul 24, 2007 at 9:05:38 AM
12
Roof problems with 2 gable roofs with different pitches. |
Sat, May 1, 2010 at 1:27:57 PM
Members: | 2056525 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
