56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Tips & Tricks >> need some help
Wed, Sep 30, 2009 at 11:54:25 AM | need some help
212plumber
ok, so this I am preparing plumbing drawings for a 60% submission for a large project. I have never used revit other than in the training I was sent to, however I am extremely capable with autocad, and am adapting well to REVIT.... that being said, here is my question: when you guys design systems, say you only want to show just main runs, not branch piping and not connected into fixtures, how do I do that without things going crazy, I am trying to run three pipes down a hallway, and have put connectors on work planes I made, and every time I connect, I cannot see the piping, even though my plans cut plane is wide enough to see both the floor and 1' above and below. I could just run piping but it seems like a waste to not use REVITs system feature from the beginning. Do you guys have any tips for creating plumbing systems from the start? should I just connect to fixtures right from go? thanks in advance for any help.
Nick
Thu, Oct 1, 2009 at 4:30:10 PM | need some help
DAVID85027
Is it possible that the display settings for that particular view it not letting you see it?  Right click on the veiw on the navagation window and goto properties.  Another window will open and click on "visability/ graphics override".  Scroll through there and see if the object you are setting is "checked".  If not, then it will not be seen in that view.
Fri, Oct 2, 2009 at 12:08:40 PM | need some help
Mattman2248
Mattman2248 Avatar
Well...you could create a union that will allow you to connect two seperate systems to each other (I think its either a global connection or a other connection) and set up seperate systems for mains and for branches allowing you just to use the filters and turn them off or on.
Revit was once a 5 letter swear word for me....
Fri, Apr 16, 2010 at 1:44:16 PM | need some help
ShnizleGhost
Well I don't know anything about it, but I was just wandering on how to make a poll.
ShnizleGhost
Page generation time: 0.1697
