32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Combining objects that are on two separate levels at the same elevation
1 Posts No Rating |
I recieved a model from a consultant that has two level 1's that are the same elevation. They drew objects on both levels. Is there an easy way to combine these two levels? Thanks.
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
You need to isolate the objects that are hosted on the wrong level and rehost them. For most objecst, you should just be able to change them under their properties - constraints - and change them to the correct level. You may have to do this piecemeal by category but you should at least be able to change them as a group.
Help Combining/merging 2 separate projects into 1 |
Thu, Oct 4, 2007 at 2:09:46 PM
Combining Elevation Tags? |
Fri, May 18, 2018 at 9:39:23 AM
Combining internal elevation tags |
Tue, Jan 11, 2011 at 4:33:22 AM
Elevation Levels Mess |
Thu, Jun 26, 2008 at 11:53:13 AM
VISIBILITY OF LEVELS |
Tue, Jul 13, 2010 at 12:45:49 PM
Members: | 2025982 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
