66 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Modifing Wall surface patterns
Thu, Sep 24, 2009 at 12:55:10 PM | Modifing Wall surface patterns
JR49
I'm trying to modify my wall surface and make it follow a path make by my stair stringer. Can anyone help with this. attached in a JPEG of what I'm trying to do.
Thu, Sep 24, 2009 at 1:05:52 PM | Modifing Wall surface patterns
4 Stars: 203 Votes
Create the wall, pick in the wall and "EDIT", change to the shape you want....
Thu, Sep 24, 2009 at 2:44:56 PM | Modifing Wall surface patterns
JR49
i tried that but it doesnt seem to work, do you know if there is a tutorial out there that can help
Thu, Sep 24, 2009 at 3:35:24 PM | Modifing Wall surface patterns
4 Stars: 203 Votes
Well, now i'm looking your image, is that green lines sweeps or reveals? can you please explain a little bit what you really want to do?? Images will help....
Thu, Sep 24, 2009 at 4:06:29 PM | Modifing Wall surface patterns
JR49
it suppose to be a multi level stair which the tiles follow the stair enclosure. the wall has a sweep which is the striaght hort. lines, the green lines represent the path that i want the sweep to follow as it goes from level to level. see the attach pdf, i drew a iso/elevation so you can see what i want to do. any help i get is better than nothing. thank you for your suggestion before.
Thu, Sep 24, 2009 at 4:15:23 PM | Modifing Wall surface patterns
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Use "split surface" tool paint bucket to apply material/pattern.
 "If you tell the truth, you don't have to remember anything"
Fri, Sep 25, 2009 at 8:50:56 AM | Modifing Wall surface patterns
JR49
thank you guys for your help, i used the split face then the paint tool and it looks the way i want it. at first it was hard messing around with it but it worked.
scale surface patterns
Fri, Aug 15, 2008 at 1:38:44 PM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:12 AM
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:35 AM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:16 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:25 PM
Page generation time: 1.4298
