60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Help with a single stone moulding window
Wed, Aug 17, 2005 at 1:13:25 PM | Help with a single stone moulding window
Magaly
I started a week ago with Revit. Can somebody indicate me a tutorial to learn how to do a window(family) with a stone moulding around??
Thu, Aug 18, 2005 at 3:31:43 AM | RE: Help with a single stone moulding window
eldados
eldados Avatar
4.5 Stars: 8 Votes
don't know about a tutorial but i would do the moulding a solid extrusion (not sweep) you will need to lock the extrusion to itself in the sketch mode (so dimension won't change) and lock the inside to the window frame, so when you change window size the moulding will change with it. am i clear enough? Smile hope so. give it a go and if you get stuck, post the file.
Arched window with stone arch above it? How to do it?
Wed, Apr 13, 2005 at 2:22:58 PM
Adding quarter round moulding to existing base board moulding
Tue, Nov 20, 2007 at 8:43:49 PM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:45 PM
Stone window surrounds
Mon, Jul 27, 2015 at 1:34:22 PM
Building Families - Window (Single Hung Sector Top)
Fri, Dec 7, 2007 at 12:19:45 PM
Page generation time: 1.3476
