118 Users Online (117 Members):
Forums >> Community >> Newbies >> Angle to column
1 Posts No Rating |
Hello to all, This is Prasad from Bangalore. I am new to Revit Structures. I am working on one of my projects from past two months. I find difficult in placing angle attached to column and base plate(please refer the attached drawing). I am not able to put angle to entire flange width. I used framing option to put angle, with the option 'pick line' and clicked the column flange line and it was taken to entire flange width, later i moved the angle to flange edge(because it was matced with the cg line of angle) and at this time the length changed(according to the start and end extension distance), i changed both the distance but eventhough its not coming properly. Before doing this i also changed the cross-section rotation to 90. Please go through the attached file and give me the solution.
Prasad, I am MAD FOR HER, But why I am not MADE FOR HER |
Angle parameter for column? |
Thu, Jan 23, 2014 at 5:38:28 PM
Using a Steel Angle as a Hanger or Column |
Mon, Oct 12, 2009 at 7:04:25 PM
Angle Column Family |
Fri, Jan 16, 2009 at 5:09:36 PM
structural column family |
Tue, Oct 25, 2005 at 9:29:56 AM
Complex Steel Columns |
Tue, Jul 1, 2008 at 10:21:51 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
