Forums >> Revit Building >> Technical Support >> Image Overlay onto Toposurface 2010
3 Posts No Rating |
Hello, I am using Revit Architecture 2010 My question is this: What is the best way to overlay a Google Earth Image onto an existing toposurface? My project needs an accurate site representation and is approximately 40 acres. I could go through the process of splitting my toposurface for each material needed for an accurate representation of the site, or I could just overlay my aerial image of the site onto the toposurface(much easier). Currently I have made a material using the image and properly scaled it, my problem now comes in that I need to be able to locate the texture on the toposurface. I'm unsure as how to offset a texture on the surface of a toposurface. It's very close, but not close enough for what I need. Attached is a render of whats going on. If you need more clarification of what I'm asking please specify and thank you for your time!! Regards,Mike
Edited on: Tue, Sep 22, 2009 at 9:02:23 PM
Rkitect did a blog on this on rtotd.com you will have to import the image from google earth into sketchup, and make sure terrain is on, then import it into revit.
J. Allen Ball Revit Architecture 2010 Certified Professional |
3 Posts No Rating |
It seems as though that web-page no longer exists, any other ideas or clarification? Thanks!!
Here is the link: http://revittotd.com/ is in there...
Toposurface |
Fri, Jan 27, 2012 at 7:54:16 AM
Glass Material with Custom Image Overlay |
Sat, Feb 19, 2011 at 3:00:16 AM
Accurately overlay and position imported CAD |
Mon, Apr 27, 2009 at 5:23:05 AM
Toposurface&subregion problems |
Thu, Apr 16, 2009 at 1:47:07 AM
Toposurface-Extra lines that shouldn't be there. Image included |
Sun, Feb 20, 2011 at 10:49:52 PM
Members: | 2115958 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
