115 Users Online (114 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Types Catalog Problem w/ Decimal Degrees
Tue, Sep 22, 2009 at 3:54:41 PM | Types Catalog Problem w/ Decimal Degrees
dan5606
I'm trying to make a type catalog that will adjust a door swing angle among other parameters. Upon loading the family into a project I get the following errors:
"Invalid column unit type: DECIMAL_DEGREES" followed by "Could not parse column header: DOOR SWING ANGLE".
Any help would be appreciated. I'll post the .rfa and the .txt.
TIA
Dan
Wed, Apr 7, 2021 at 1:15:59 PM | Types Catalog Problem w/ Decimal Degrees
hanbyjm
I am trying to load a family and get the following error - "Invalid column unit type: POUNDS".  I found this in the help.
Families with type catalogs cannot be upgraded to Revit 2021
2021-02-01
Technical Support
Issue: When upgrading families with type catalogs to Revit 2021, "Invalid column unit type: ..." or "Could not parse column header: ..." appear.
Causes:
In family type catalogs and other database export operations, units and related objects are identified by specially formatted text strings.
Revit 2021 introduces corrections and formatting changes to these database identifiers. Content generated in earlier versions of Revit may need to be updated for compatibility with Revit 2021 if it includes references to certain identifiers. The changes are listed in Units in the Revit 2021 Help.
Solution: Manually edit the type catalogs to incorporate the new unit types.
Products: Revit;
Versions:
2021;
Click on the units link and scroll down to the chart and find the replacement word for the .txt file.
Edited on: Wed, Apr 7, 2021 at 1:52:44 PM
Suggestion Requiired - Types Catalog
Fri, Nov 27, 2009 at 7:30:48 AM
Level Display (only) to decimal feet
Sun, Aug 10, 2014 at 11:00:01 PM
11
showing angular dimensions in degrees seconds etc
Wed, May 5, 2004 at 7:43:16 AM
Revit Base and Survey Point Long & Lat Format
Wed, Jun 13, 2018 at 11:14:42 AM
Type Catalog
Mon, Mar 13, 2006 at 1:58:57 PM
Page generation time: 2.1799
