101 Users Online (99 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Masking not working with detail components.
Tue, Sep 22, 2009 at 3:53:47 PM | Masking not working with detail components.
KBdeal
I have a window mullion family with a nested rigid insulation family.  I have the typical parametric dimensions.When I load the family in the central file, I cannot get the break lines to mask.  It almost appears that the break line is below the detail.  I have used the detail component template to create both families.  I have tried to reorder the break line.  I have changed the view properties to hidden line.  I have tried to mask region just in case it was the break line.Out of ideas.GONE.
Tue, Sep 22, 2009 at 5:09:05 PM | Masking not working with detail components.
mhans
3 Stars: 10 Votes
Hi,
Check if you are in Wireframe mode. Also, can you not nest the rigid insulation?
Motto: "No Post left behind"
masking linework behind components
Wed, Apr 5, 2006 at 6:03:29 PM
Visibility/Graphics and Detail Components
Wed, Feb 23, 2011 at 2:53:37 PM
Detail components in multiple views.
Tue, Aug 18, 2009 at 2:46:36 PM
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:23 PM
Detail components
Fri, Sep 14, 2007 at 9:13:43 AM
Page generation time: 2.3587
