Forums >> Revit Systems >> Technical Support >> Is this possible to do now in 2009 or 2010 MEP to schedule all elements of
Tue, Sep 22, 2009 at 9:47:48 AM | Is this possible to do now in 2009 or 2010 MEP to schedule all elements of
jcrocco
3 Stars: 1 Votes
Is this possible to do now in 2009 or 2010 MEP to schedule all elements of Plumbing or Mechanical systems?
I would like to be able to generate BOM's for these two systems.
For the piping, I dont know if each fitting (IE: 90 deg 1" el, 90deg 3/4" el, 1" Tee, 2x2x1 Tee, etc) can be scheduled seperately.  Revit seems to group them all the same.  Also, is ther a way to get the total amount of linear feet of 3/4" piping, 1" piping, etc?  AND, how do you count the connectors between pipes?  If I have a 50 foot run, thats 5 10ft sections, and 4 connectors?  Is there a way to do this?
Same goes for mechanical.  Is there a way to get an itemized listing of all ductwork and fittings?  If not automatically, could I build it with families, say a 10x10x59.5" rectangular duct, assembled end by end, so in a schedule it would list each segement, and each fitting.
I am just starting to play around with the schedules, but it seams things are currently limited.
Has anyone done this, tried it, or found it worthwhile or not worthwhile to do?
Tue, Sep 22, 2009 at 10:24:08 AM | Is this possible to do now in 2009 or 2010 MEP to schedule all elements of
3.5 Stars: 395 Votes
Schedules in REVIT are not limited very much at all.  THey are part of the power of REVIT. Every element in REVIT can be scheduled.
This might put you on the right path... include a column that is family type... filter by this column for  90deg3/4 el ...or whatever...  And hide the column.  (Probably don't want to show all instances and want a count and total fields)
Learn to use filters, sorts and hides to get what you want.  Explore and your will be amazed.
Linking 2009 with 2010
Wed, Aug 10, 2011 at 4:03:57 PM
Saving frpom 2010 to 2009
Wed, Jul 13, 2011 at 2:13:05 PM
Opening a 2010 file in 2009
Thu, Jul 16, 2009 at 8:51:56 AM
Visibility/Graphics control on imported MEP model
Tue, Mar 9, 2010 at 12:53:13 PM
Move Loads Around in Panel Schedule
Tue, Feb 23, 2010 at 3:06:53 PM
Page generation time: 0.8516
