64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Fascia won't miter
![GlobalDS Avatar](user_avatar/115396.jpg)
![4 Stars: 1 Votes](/images/stars_4.gif) |
I have had this issue several times. Please see the attached image. In this case there are 2 roofs joined @ 45 degrees. When I put in the fascia they do not connect, and I cannont manually force them to connect. The roofs join fine, but I can't find a way to join the fasca's. I have tried both doing them as a single fascia and as 2 different ones, but I cannot make it work. Frustrating!
www.globaldesignstudio.com
Be Inspired! |
![3 Stars: 10 Votes](/images/stars_3.gif) |
The reason being your 2 facias are of different height. Try to model a sweep instead for the horizontal facia and use "join" to attach it to the diagonal facia.
Motto: "No Post left behind" |
Thanks for the response mhans. I will keep this in mind for future reference, however the fascia's I'm trying to connect are the same height. I resolved the problem, the issue is that the fascia won't extend past the original footprint of the roof before it was joined. I had to go back and modify the roof footprint to meet at the corner, then I was able to extend the fascia.
Be Inspired! |
where is fascia miter? |
Thu, Sep 15, 2005 at 10:52:36 PM
fascia won't miter on sloped roof |
Sun, Feb 3, 2008 at 7:15:58 PM
How to miter a fascia on a sloped roof? |
Fri, Aug 24, 2012 at 7:48:23 AM
Fascia Gutter Miter |
Wed, Mar 4, 2009 at 3:11:14 PM
RAC09 - Roof Fascia Corner Miter on Square Cut |
Wed, May 27, 2009 at 6:57:00 PM
Members: | 2022524 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
