52 Users Online (50 Members):
Forums >> Revit Systems >> Technical Support >> slanting wall
2 Posts No Rating |
How to create slanting wall in revit 2009. I can do this with massing but I want a wall.. I know this is possible to create slanting wall but how? and another thing how to create a circular slanting wall without using massing? please help. this is my next project..
There are several threads about this same issue here in the forum, try to search them, also there are several videos about this, i did post several in the past, you can do this in the several ways but the most simple in go to Massing, create a solid blend (top and bottom) with the inclination you want then finish the mass and in the massing you have the "Wall By Face", click in the faces you want and DONE...
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
Use an in-place family of category 'wall' and use the solid sweep or sweep blend.
Slanting Wall vs Window inserts |
Tue, Apr 19, 2005 at 7:51:49 AM
HOW TO CREATE A SLANTING STRUCTURES USING REVIT 2014 |
Wed, Jul 9, 2014 at 8:23:04 AM
intersecting inner walls with slanting outer walls |
Wed, Feb 27, 2013 at 7:51:10 AM
Walls Problems |
Mon, Nov 22, 2004 at 5:39:25 PM
Slanting walls along a beam |
Wed, Mar 29, 2017 at 4:07:54 PM
Members: | 2017305 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
