60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elevation Shadow Study
Sat, Sep 19, 2009 at 5:18:06 PM | Elevation Shadow Study
bulfii
Dear All Revit users,
I wish there is a simple way in Revit 2009 or 2010 of studying the impact of the shadow elevation on the adjoining neighbours in an orthogonal mode. At the moment the only available way ( and correct if i am wrong) is to create the study in Revit 2008 where you can use the old rendering engine to adjust the cutting sectional box that will determine the shadow range.
If my information is old, can anyone update me, and if i am right, can we add this to the wish list.
Regards
Alan Mhanna
www.mhannadesign.com
Sun, Sep 20, 2009 at 8:52:00 AM | Elevation Shadow Study
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Use the regular shadow study tools to setup tha shadow study for location, time frame etc. and orient a '3d view' to an orthagonal point of view. Then run the animated study etc.
So 'duplicate a regular 3d view' and then use the 'view cube' to re-orient that 3d view to an orthagonal point of view. Then you have an orthagonal view point from within a 3d view. This allows you to use the shadow study tools.
Animated Shadow Study CADclip Tutorial
Mon, Jan 8, 2007 at 6:22:52 PM
Trees not casting shadows on shadow study??
Sun, Apr 3, 2011 at 12:14:34 AM
11
3d elevation shadow problem
Fri, Feb 15, 2013 at 5:07:01 PM
Revit tree not showing shadow in realistic or rendered view
Fri, Mar 18, 2016 at 10:37:29 AM
Interior Shadow Studies
Sat, Feb 27, 2010 at 3:05:10 PM
Page generation time: 0.3992
