27 Users Online (26 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> RevitMEP 2010 - Fixing Errors - "Check Duct Systems" + "Check Pipe Systems"
Fri, Sep 18, 2009 at 11:59:29 AM | RevitMEP 2010 - Fixing Errors - "Check Duct Systems" + "Check Pipe Systems"
autocadisfaster
How do you fix these errors:   ??????
Mechanical Errors:
"unnassigned flow on connector"
"unassigned flow direction on connector"
"Mechanical Supply Air "X" is not well connected"
"not possible to calculate flow due to flow direction mismatch. Check flow direction on all equipment in system"
 Piping Errors:
"not possible to calculate flow....... at least one component is required to have flow configuration set to Calculated"
"..... not well connected"
Comment:
This is just the begenning of my problems... so far Revit looks great but functions poorly with an unfriendly interface.
I am an AutoCAD user since R12 DOS, currently using 2010 and have plenty of other software/ programming skills.
Revit MEP, IMO, is not ready. So if you can prove otherwise I am waiting...
Forcing the "System Type" Parameter
Fri, Sep 3, 2010 at 11:35:01 AM
Mirroring entire project- "copy" check box greyed out?
Sun, Apr 23, 2006 at 6:44:57 PM
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:19 PM
HVAC Systems
Wed, Sep 16, 2009 at 7:03:08 AM
changing the "family" and "type" names
Mon, Apr 2, 2007 at 5:33:49 PM
Page generation time: 8.2521
