54 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Crop Region out in space
Fri, Sep 18, 2009 at 10:33:55 AM | Crop Region out in space
apanico
I had to move an entire building to a different location in a file.  Now, when I check the crop view box, the building disappears - presumably being cropped.  When I zoom to fit, the crop box appears.  I am assuming that the crop box is back at it's original location - where the building used to move.  I can't seem to find the building to locate the crop box over it - does anyone have any suggestions?  I realize this is a muddled question, but this is very strange.
Fri, Sep 18, 2009 at 10:37:09 AM | Crop Region out in space
apanico
Also, I managed to locate the crop region box in the 3D view and get it aruond the building - but now I can't find the section box.  I'm basically looking for some way to get these boxes to where the model now is.
Fri, Sep 18, 2009 at 10:43:51 AM | Crop Region out in space
apanico
Fri, Sep 18, 2009 at 10:48:05 AM | Crop Region out in space
apanico
Fri, Sep 18, 2009 at 11:09:11 AM | Crop Region out in space
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Tough to answer in a post without investigating your model.
There is a video training series on this topic that will explain it all here > http://www.myvbooks.com/cadclipsstore/stores/1/Datums_Crop_Regions_and_Scop_P57C12.jsp
It is a little out dated but the information still applies.
Fri, Sep 18, 2009 at 1:47:40 PM | Crop Region out in space
apanico
Thank you. I finally found the crop region and relocated it.
Room Tags Outside Crop Region
Sun, Sep 10, 2006 at 8:05:27 PM
imported grid offset from crop region
Fri, Sep 19, 2008 at 4:47:11 AM
crop region changes when placed on sheet
Fri, Jan 9, 2015 at 3:33:08 PM
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:30 PM
crop region - elevations
Fri, Oct 23, 2009 at 12:43:34 PM
Page generation time: 2.4183
