46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Discipline view settings
Thu, Sep 17, 2009 at 1:53:47 PM | Discipline view settings
rjudd
Anyone know how or if you can modify how the "Disciplines" control under view/graphics affects display.  Or is it a Revit default?  Have had no success searching the help or internet.  This setting obviously changes how objects are displayed when you apply it.  Tying to understand how and if it can be customized.
Thu, Sep 17, 2009 at 2:36:59 PM | Discipline view settings
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You cannot modify, rename or add a discipline. The disciplines themselves are fixed. Here's some info that may help.
It depends on if you are using RAC/RST or RME. The impact of setting the view discipline in REVIT is not very well documented in the help menu and it missed out on a fair bit of important information. Too much to try to explain in a simple post.
A model view has the option to set the 'discipline'. If you are in RME for example and set the discipline to Mechanical or Electrical then the RAC / RST objects will follow the 'Underlay' settings (regardless if the objects are local or linked). If you are in RAC and set the discipline to Architecture the RME items follow the 'Underlay' settings. Discipline 'coordination' is a combination of RAC + RST.
The 'default discipline' to be applied to newly created views is specified in the 'Options' dialog box.
The discipline is usually the top sorting criteria for the Project Browser but RME uses Sub-Disiplines and Classifications as well to organize the project browser. Sub-disciplines and classifications are editable.
We have a brand new 'Getting Geared Up With RME 2010' training series that covers all of this and much more here > http://www.myvbooks.com/cadclipsstore/stores/1/Getting_Geared_Up_with_Revit_M_P210C27.jsp
You can get 20% off any REVIT training from our site for the next 7 days using this coupon > REVITCITY-CADCLIPS
These are the lessons from the 'Getting Geared Up With RME 2010' series:
  • Lesson 1: Introduction and RME Options
  • Lesson 2: Setup Tutorial Places and Open Existing Project
  • Lesson 3: Course Overview
  • Lesson 4: REVIT Windows
  • Lesson 5: Project template Files
  • Lesson 6: Adding Content to the RAC Model
  • Lesson 7: Using the Paste Align tools in the RAC Model
  • Lesson 8: Investigating the RAC Model Using the Section Box
  • Lesson 9: Investigating the RAC Model by Plan and Section Windows
  • Lesson 10: Investigate the RAC Model Using View Templates
  • Lesson 11: Investigate the RAC Model Using Filters and Temporary Visibility
  • Lesson 12: Investigate the RAC Model for Room Instances
  • Lesson 13: Cleanup the RAC Model Using Delete and Purge
  • Lesson 14: New Project, Delete Levels, Import RAC Model
  • Lesson 15: Copy Monitor Levels and Grids
  • Lesson 16: View Properties and the Project Browser
  • Lesson 17: New Views for HVAC Floor Plans, Ceiling Plans, 3D and Elevations
  • Lesson 18: New Views for Plumbing Plans and 3D
  • Lesson 19: New Views for Electrical Plans for Lighting, Power and Telecom
  • Lesson 20: New Views for Fire Protection Plans and Ceiling Plans
  • Lesson 21: New Views for Zones and Spaces
  • Lesson 22: View and View Title Renaming
  • Lesson 23: Project Browser Organization and Sub Disciplines
  • Lesson 24: View Discipline, Sub Disciplines and Underlays
  • Lesson 25: Intro to View Templates
  • Lesson 26: HVAC, Space and Zone View Templates
  • Lesson 27: Electrical and Plumbing View Templates
  • Lesson 28: Visibility Tips
  • Lesson 29: Add Spaces, View Templates and Wall Function
  • Lesson 30: Adding Zones
  • Lesson 31: Create Plenum Plans for HVAC and Zone Editing
  • Lesson 32: RME / RAC Connectors and Copy Paste-Same Method
Depedning on if you use
Controlling Display setting per Discipline
Fri, Feb 17, 2012 at 12:33:05 PM
View Discipline Parameter
Mon, Mar 4, 2013 at 3:08:41 PM
"Discipline" settings effecting two models differently
Mon, Aug 17, 2015 at 1:19:26 PM
Sub Discipline under Views?
Fri, Apr 17, 2009 at 2:21:22 PM
Discipline showing to light
Tue, Jun 26, 2012 at 9:22:48 AM
Page generation time: 2.2715
