76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Increase Darkness of Halftone
Thu, Sep 17, 2009 at 9:34:27 AM | Increase Darkness of Halftone
emmettking
I am in Revit Architecture 2009.  When printing documents we print them as a PDF and when the outside source printer prints the docuemnts the halftone items show up as too lite or not at all.  is there a way to increase the darkness of the half tone items when printing?
Thu, Sep 17, 2009 at 10:48:19 AM | Increase Darkness of Halftone
Prophecy99
Prophecy99 Avatar
First i would check your print settings and make sure your using "black lines" instead of grayscale.  I noticed that helped most of the time while still maintaining halftone results.
Second If that dosent work or dosent apply I would check what you have half toned and see if by changing it to a regular tone and darker gray color instead of halftone black you may achieve the results you are looking for.
Edited on: Thu, Sep 17, 2009 at 10:49:32 AM
Imagination reveals truths reality obscures.
Thu, Sep 17, 2009 at 12:11:41 PM | Increase Darkness of Halftone
emmettking
That is not the answer that I had hoped.  I was hoping there was a setting for halftone as a percentage of black.  There is just too many items and views to go through to make those changes.  hopefully it can be changed on the printer end.
Thu, Sep 17, 2009 at 2:52:50 PM | Increase Darkness of Halftone
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Hate to say it but . . . REVIT 2010. . . . full control over Halftone density and Underlay line weight and line pattern.
Thu, Sep 17, 2009 at 2:55:57 PM | Increase Darkness of Halftone
See folks... they did put in some new, requested features in 2010.
Thu, Sep 17, 2009 at 3:01:35 PM | Increase Darkness of Halftone
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
No way I could go back to 2009.
Tue, Oct 13, 2009 at 8:08:00 AM | emmettking
Prophecy99
Prophecy99 Avatar
Quoting emmettking from 2009-09-17 12:11:41
"That is not the answer that I had hoped.  I was hoping there was a setting for halftone as a percentage of black.  There is just too many items and views to go through to make those changes.  hopefully it can be changed on the printer end.   "
Depending on how you did things it may not be too hard.  View filters do wonders for things like this !
darkness falls
Thu, Dec 2, 2004 at 1:21:09 PM
Background fade during Boundary Edit
Mon, Nov 3, 2014 at 12:01:27 PM
Design Options Halftone?
Tue, Nov 20, 2018 at 10:58:56 PM
Revit MEP 2012 - Halftone not Working...
Fri, Oct 5, 2012 at 12:47:21 PM
halftone hatch/fill pattern?
Wed, Jan 16, 2008 at 10:14:12 AM
Page generation time: 0.3526
