50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Sweeps or In-Place Family Sweeps
Wed, Sep 16, 2009 at 12:35:47 PM | Wall Sweeps or In-Place Family Sweeps
BDerrick
3.5 Stars: 3 Votes
Which do you use? why?  Problems you've had with either one?  Which would you recommend?
Wed, Sep 16, 2009 at 4:44:38 PM | Wall Sweeps or In-Place Family Sweeps
Bronsart
I like in-place family sweeps because it's easier to control the returns.  It depends on what you are using the sweeps for.  I use the sweeps mostly for stone or cantera wall caps.
Wed, Sep 16, 2009 at 5:18:48 PM | Wall Sweeps or In-Place Family Sweeps
BDerrick
3.5 Stars: 3 Votes
Mainly we use the tool for room base boards.  Sometimes it's necessary for us because there are so many different profiles throughout the project.  What's nice about the wall sweep is that it automatically cuts it when there is an opening/door.  But in in-place families, I think it's tedius to pick all the lines and then slice the line where there's an opening.  However, when walls change location, in-place families hold on to there host much better than wall sweeps.
Wed, Sep 16, 2009 at 8:07:37 PM | Wall Sweeps or In-Place Family Sweeps
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
I think as long as you look down the wall sweeps correctly then there is not much need for in place families when it comes to sweeps.
J. Allen Ball
Wed, Sep 16, 2009 at 8:07:58 PM | Wall Sweeps or In-Place Family Sweeps
AllenBall
AllenBall Avatar
4 Stars: 9 Votes
Lock*
J. Allen Ball
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
Angling Wall Sweeps
Vertical Wall Sweeps
Wed, Nov 7, 2007 at 4:46:08 PM
Outlets and Wall Sweeps
Wed, Feb 29, 2012 at 9:39:46 AM
Can you rotate wall sweeps?
Wed, May 2, 2012 at 9:23:44 PM
Page generation time: 1.6948
