133 Users Online (131 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Dome roof openings
Mon, Aug 15, 2005 at 3:16:42 AM | Dome roof openings
fazerneil
4 Stars: 5 Votes
Anyone know what is the best way of creating openings in a dome roof. I have tried a standard opening cut vertically, but as opening is not cut perpendicular to the curved face it does not look right. Also it is trial and eroor as to where opening is with regard to cill height as you have to cut opening from above, not in elevation. Also, how could I add model "ribs" to the dome to simulate joints in metal cladding ? On a standard pitched roof you could just create a ridge/hip profile but their are no lines to select on a dome ?
Mon, Aug 15, 2005 at 6:24:02 PM | RE: Dome roof openings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Use an in-place family void to cut the dome in elevation. You'll find it more accurate as you can cut in elevation if needed. If you want to get the ridges then i suggest changing the segments to an appropriate value rather than smooth (0) as this would be more correct and then allow your the edges your require for the profiles. HTH.
Tue, Aug 16, 2005 at 3:37:25 AM | RE: Dome roof openings
fazerneil
4 Stars: 5 Votes
Thank you Mr Spot.
Dome roof
Mon, Jan 17, 2011 at 7:52:23 AM
14
Dome Roof?
Mon, Oct 1, 2007 at 2:16:40 PM
Dome Roof
Wed, Sep 27, 2006 at 12:32:47 AM
Create a half dome
Mon, Nov 11, 2019 at 5:37:43 PM
Dome Roof for Astronomy club
Tue, Jan 31, 2006 at 4:08:08 PM
Page generation time: 1.0973
