68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Steel framing not showing on plan
Tue, Sep 15, 2009 at 4:09:12 PM | Steel framing not showing on plan
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
Hello,
 I have a steel frame that has a low roof and a high roof (stepped roof) I created a level for both, but I want to show them on the same plan. I am using the high level roof as the default and I set the Depth view accordingly so tha tI can also see the lower roof framing on the same plan. Some Girders show up and some don't and I am no sure why that is, any ideas?
I tried different view depths. The girders are there, since they do show up on the lower roof view. and they alsso show up on the 3D model.
 Any haelp would be greatly appreciated
Welcome to the REvitlution!!!
Wed, Sep 16, 2009 at 11:24:17 AM | Steel framing not showing on plan
Sigfinnur
Vanrevit,
Have you tried to use plan region?
Finn.
Wed, Sep 16, 2009 at 11:33:37 AM | Steel framing not showing on plan
Since some of them on the same level show up, plan region is not the solution.  Make sure they are not hidden individually in view.
Are you in Revit structure?
Wed, Sep 16, 2009 at 2:49:57 PM | Steel framing not showing on plan
VANREVIT
VANREVIT Avatar
5 Stars: 2 Votes
I am no Revit Structure 2010. I don't have any hidden items. It is just that some beams show up and other don;t and they were drawn on the same plane
Wed, Sep 16, 2009 at 2:58:35 PM | Steel framing not showing on plan
VG - Turn on all sub-categories under structural framing.  You may have placed these elements in the wrong sub-category.
Horizontal Steel Framing ????
Fri, Apr 5, 2013 at 8:18:09 AM
Can't see Structural Framing from attached Revit Link in any Floor Plan
Thu, Mar 8, 2018 at 3:01:12 PM
11
TOS in framing tags?
Thu, Apr 22, 2010 at 9:37:23 PM
Steel Structure Object Style
Fri, Feb 22, 2019 at 5:51:23 AM
wood framing plan
Wed, Dec 31, 2014 at 9:10:13 PM
Page generation time: 1.3239
