40 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering without a sky (alpha transparent) (2010)
Tue, Sep 15, 2009 at 12:46:08 PM | Rendering without a sky (alpha transparent) (2010)
HGL5
I've read solutions for this in the forums, but it seems to be for 2009 and earlier, because I dont see where to click for alpha render.  Can someone describe where the setting is for alpha renders in 2010. Thank You
Tue, Sep 15, 2009 at 12:46:55 PM | Rendering without a sky (alpha transparent) (2010)
HGL5
Also if it's possible to get rid of the ground revit likes to put in, how is that done?
Tue, Sep 15, 2009 at 1:21:18 PM | Rendering without a sky (alpha transparent) (2010)
tim123
4 Stars: 19 Votes
Export the image and save it as a TIFF file.  This will remove the ground also.
Tue, Sep 15, 2009 at 1:52:54 PM | Rendering without a sky (alpha transparent) (2010)
HGL5
Tue, Sep 15, 2009 at 2:26:21 PM | Rendering without a sky (alpha transparent) (2010)
tim123
4 Stars: 19 Votes
Exporting as a TIFF will remove the ground also.
Thu, Sep 17, 2009 at 1:39:18 PM | Rendering without a sky (alpha transparent) (2010)
HGL5
Saving as a TIFF does not work. TIFF's do not even recognize transparent layers. Needs to be a GIF or PNG....
Thu, Sep 17, 2009 at 3:19:43 PM | Rendering without a sky (alpha transparent) (2010)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
As far as I know exporting as a tiff removes everything except the building and leaves the surrounding space as transparent. Have not tested in 2010.
Then you can re-import that image and overlay it on a background image and use the 'move to front / back' tools.
Edited on: Thu, Sep 17, 2009 at 3:21:32 PM
Thu, Sep 17, 2009 at 4:14:57 PM | Rendering without a sky (alpha transparent) (2010)
HGL5
Fri, Sep 18, 2009 at 7:21:06 AM | Rendering without a sky (alpha transparent) (2010)
tim123
4 Stars: 19 Votes
Needs to be a TIFF or a PNG.  A GIF does not contain transparent layers.
Fri, Sep 18, 2009 at 9:45:49 AM | Rendering without a sky (alpha transparent) (2010)
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
So I am not 100% sure of your application of the transpparent layering is but I guarantee that Tiff supports transparent layering because I have used it in my training and the Tiff file format has not changed since 1992.
Perhaps this will explain. Go to this page below and on the left side click 'REVIT 2009 Miscellaneous' > Rendering with Background Images. Watch that video. (right click and zoom to full screen) At approx. 2:30 into that video I export as Tif and then re-import it into a drafting view and use the transparency to underlay a background image.
Perhaps REVIT 2010 has changed the export as Tif format? Have not tested yet.
CADclips Free Videos
Wikipedia actually says GIF, Tiff and PNG all support transparent layers.
http://en.wikipedia.org/wiki/Transparency_(graphic)
more info:
http://en.wikipedia.org/wiki/Layers_(digital_image_editing)
http://en.wikipedia.org/wiki/TIFF
Edited on: Fri, Sep 18, 2009 at 10:07:42 AM
Edited on: Fri, Sep 18, 2009 at 10:08:40 AM
Revit 2010 rendering & sky options
Thu, Dec 8, 2011 at 1:08:33 PM
Trouble with sky for rendering
Wed, Jul 21, 2010 at 9:10:26 AM
Rendering Questions re Sky
Tue, Sep 19, 2006 at 4:34:00 PM
Revit 2008 & exporting alpha chennels
Wed, Sep 5, 2007 at 2:28:18 PM
Rendering in Revit 2009 [ 1 2 ]
Thu, Dec 31, 2009 at 10:41:31 AM
19
Page generation time: 23.6614
