69 Users Online (68 Members):
Forums >> Revit Building >> Technical Support >> revit file too heavy when importing into 3dsmax
5 Posts No Rating |
hello Again,i've got revit file which is 20++ MB, my problem is: when i import into 3dsmax for walkthrough, it was very slow to editing. How to solve this kind of problem. Is that my revit modeling?
![alabaster2513 Avatar](user_avatar/28262.jpg)
![3.5 Stars: 25 Votes](/images/stars_3.5.gif) |
20MB is tiny. are you new to max?
5 Posts No Rating |
i'm using max since 2007,but i using with 3d autocad then import to max, for revit is quite new for me, but the basic still the same right? how can i make all curtain wall become 1group at least,because when i export into .dwg file,too many layer from revit, how can it compress itself?
under customize/files you can set your max file to compress on save. I do not use the Revit-DWG-Max workflow, I use Revit-FBX-Max workflow which is not available in Max 2007 so i cannot help with the grouping.
Saving to 3dsMax? |
Mon, Jul 10, 2006 at 3:03:49 PM
how to transform my 3d from 3dsmax into technical drawing |
Mon, Jan 19, 2009 at 1:32:51 PM
Revit to 3Dsmax vray glass problem |
Tue, Jan 21, 2014 at 8:47:01 AM
Linking Revit to 3dsmax 9 sp1 |
Tue, Jun 26, 2007 at 11:05:38 AM
Revit to 3dsMax for GPU utilization |
Fri, Dec 21, 2012 at 12:12:35 PM
Members: | 2017201 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
