117 Users Online (116 Members):
Forums >> Revit Building >> Technical Support >> can't save as a central file
23 Posts No Rating |
Recently updated to revit 2010 and for some reason when I try to save my file as a central file it won't allow me to check the "make this a central file after save" option. Is there a different way to take an existing file and turn it into the central file? I even tried a simple save as, and putting it into a different location hoping any changes i made would prompt me to save to the central file and from thee I could set it up but no luck!? please help. Dave T
Before you can save as a central file, you have to enable worksets.
thanks that worked. much abliged!
can't view file properties - central path |
Fri, Aug 21, 2009 at 2:34:53 PM
Worksets/Central files |
Tue, Jul 24, 2007 at 2:26:31 PM
can not save a central file |
Thu, Mar 20, 2014 at 2:28:30 PM
Template won't allow "make a central file" |
Mon, Jun 23, 2008 at 2:07:08 PM
detach from central file |
Wed, May 12, 2010 at 12:28:23 PM
Members: | 2056329 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
