52 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Components Will Not Load Under Any Circumstances!
Sun, Sep 6, 2009 at 11:23:42 AM | Components Will Not Load Under Any Circumstances!
ksmith
Firstly let me just say that I have researched this problem on the forum here and have read many notes about it but none that answer or solve the problem. This is what's happening : -
I am using Revit 2010 and I try to load a component into my model. The path to the component I am trying to load is Metric Library > Detail Components >  Disposal Systems > Foul Drainage Above Ground > Roof Drain-Section (1)
I just cannot load this Roof Drain Section no matter what I try.
I just get the previous component that I loaded that comes up. After selecting the component I have tried clicking the arrow under components to see if I can see the component there to select again but it is nowhere to be found. In fact, I have tried just about everything I can think of to try and load the component but absolutely no joy at all.I just keep on getting the previous component!!
Is this a fault or bug with Revit??
as I say, I have read a few posts on other people suffering from the same problem but no definite solution on how to overcome it.
So this is to all you Revit guru's or anybody who can stop me tearing out what hair I have left on my head.
How do I load this component???
Thank you for any help
Kirk
USING REVIT 2011--- This old builder is determined to Learn Revit no matter what it takes.
Sun, Sep 6, 2009 at 11:44:50 AM | Components Will Not Load Under Any Circumstances!
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Did you try by searching it in your Project Browser and then drag it to your project?....
Edited on: Sun, Sep 6, 2009 at 11:47:34 AM
Sun, Sep 6, 2009 at 12:10:39 PM | Components Will Not Load Under Any Circumstances!
ksmith
When I go into a 2d view I can see the component there and drag it in to my model. Can I see this is 3d view though? as at the moment I cant at all!
Thanks
Sun, Sep 6, 2009 at 12:35:49 PM | Components Will Not Load Under Any Circumstances!
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Did you read your HELP menu?....
Sun, Sep 6, 2009 at 1:38:00 PM | Components Will Not Load Under Any Circumstances!
ksmith
Seems that I overlooked that one! Thanks for pointing that out.
Cannot Load Components from Library
Wed, Jun 1, 2016 at 6:31:17 AM
How may I load the rcp file for some components?
Fri, Jun 1, 2007 at 8:08:09 AM
problem loading components
Sun, Apr 26, 2009 at 2:21:19 PM
Problem loading components
Mon, Sep 28, 2009 at 3:43:41 AM
cant find components
Mon, Aug 15, 2011 at 11:23:59 AM
Page generation time: 1.6953
