79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked File, how can I dimension it?
Fri, Sep 4, 2009 at 5:50:06 PM | Linked File, how can I dimension it?
markuspirker
I am working on a townhouse project and  created each unit as a linked revit file.
Now that I have put it all together
and toggled the visibility setting just the way I need it I can't get my dimensions to snap to the walls in linked files properly.
I only can snap to the core center line of the linked revit file,
but I need to be able to snap to core faces of walls in linked elements. How do I do that?
Fri, Sep 4, 2009 at 8:42:24 PM | Linked File, how can I dimension it?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
On the Options Bar, for Prefer, select Faces of Core.
Sat, Sep 5, 2009 at 12:15:36 AM | Linked File, how can I dimension it?
markuspirker
Nope, that does not work with linked files.  I tried again both in RVT2009 and RVT2010. Could it be that this is a bug?
Sat, Sep 5, 2009 at 3:05:45 AM | Linked File, how can I dimension it?
tim123
4 Stars: 19 Votes
When you select the wall, use the tab key to cycle through the faces until you get to the one that you want to dimension to.
Sat, Sep 5, 2009 at 12:25:57 PM | Linked File, how can I dimension it?
markuspirker
It's so obvious, isn't it? I should have figured it out myself Smile Thanks.
Sat, Sep 5, 2009 at 3:14:01 PM | Linked File, how can I dimension it?
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"Nope, that does not work with linked files."
markuspirker: in the example I posted before, I used a linked Revit file and didn´t have any problems even without the need of selecting walls with the tab key....
Edited on: Sat, Sep 5, 2009 at 3:17:11 PM
Sat, Sep 5, 2009 at 3:39:47 PM | Linked File, how can I dimension it?
tim123
4 Stars: 19 Votes
I could also select the faces with the linked file with faces checked.
Sun, Dec 19, 2010 at 8:08:51 PM | Linked File, how can I dimension it?
ScopeDrafting
I Know this post is over a year old but I had the same proble. The solutions listsed above didn't work for me. I eventually found the sloution being the settings in the linked revit file. I changed the cut and view planes then could dimension no problem.
Nathan
Dimensioning across multible linked files
Fri, Jan 15, 2010 at 10:33:17 AM
Dimensioning with linked DWG files
Sat, Nov 12, 2011 at 4:20:07 PM
Invalid Dimension to linked AutoCAD file.
Tue, Mar 13, 2007 at 11:24:23 AM
Dimension issues when exporting to AutoCAD
Mon, Nov 19, 2007 at 4:51:14 PM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:17 PM
Page generation time: 1.1152
