54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Fill Patterns Drafting / Model
Fri, Sep 4, 2009 at 9:35:32 AM | Fill Patterns Drafting / Model
Casparos
Hi all,
I would like to combine 2 fill patterns, like A+B in the enclosed image, [brickwork + block layering]
Is there a way to do this, I prefer model patterns.
And Actually C' above C, how to programm these, is there a tutorial how to?
Cee
Fri, Sep 4, 2009 at 12:27:12 PM | Fill Patterns Drafting / Model
tim123
4 Stars: 19 Votes
You can create the pattern in the revit pat file.
I suspect that you might want to use this for the cut material in a wall, but you cannot use model patterns for these.  However, the repeating blockwork detail would work well for that.
Tue, Sep 8, 2009 at 8:06:41 AM | Fill Patterns Drafting / Model
MARS1276
1 Stars: 1 Votes
Something else you can do (which I have done myself) is create the patterns as 'transparent' instead of 'opaque'.  That way what is underneath will show through.  Doing this with both pattern types will allow you to stack the two on top of the other and get the appearance you want.
Otherwise you may have to do what tim123 mentioned.
Model Fill Patterns
Tue, Jun 22, 2010 at 11:35:20 PM
create/ convert hatch patterns (.pat) to revit fill patterns
Tue, Jun 2, 2015 at 11:29:01 AM
Fill Regions not deleting
Thu, Oct 8, 2020 at 3:52:55 PM
Rotate Model Fill Patterns
Wed, Sep 2, 2009 at 11:01:19 AM
14
Keynoting and Fill Patterns
Thu, Nov 1, 2007 at 6:45:19 AM
Page generation time: 0.8033
