98 Users Online (97 Members):
Forums >> Revit Systems >> Technical Support >> compressing revit file
6 Posts No Rating |
hi outthere, anyone,how do i compress revit file aside from isolating and grouping elements. ? thanks
There is a compress function and audit in your file management. If you mean other than that, grouping is not necessarily a good thing. Be careful with that. You can purge the file of un-wanted families but also be careful with that. Removing views that are not used will also reduce the size. And finally... be very careful in using CAD imports - in both the project and families. There are some good threads here on that subject and AutoDESK U has a good writeup on managing CAD imports.
6 Posts No Rating |
ok, thank you wwhub
Walkthrough rendering stops |
Mon, Feb 22, 2010 at 4:30:51 AM
12
Linked Revit Topography file displayed in hidden lines in 3d view main bld file |
Sat, Jul 7, 2012 at 3:38:16 PM
Scheduling from linked Revit file |
Tue, Mar 27, 2012 at 7:39:28 AM
Need HELP!! Geting a Navisworks file inn to Revit Structure |
Mon, Apr 8, 2013 at 8:02:00 AM
STAIRS IN LINKED FILE WON'T SHOW UP IN MAIN CENTRAL FILE 3D |
Mon, Jun 25, 2012 at 3:58:52 PM
Members: | 2017117 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
