57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> GUTTER PROFILE not appearing in sections?
30 Posts No Rating |
Hi guys, using 2010. Created a profile which shows Csection, flashing and gutter. and using it as a gutter family. it works fine it appears in 3D and elevations but on my section views that cut through it i cant see it. I need it there and details? Thanks.
4 Posts No Rating |
Hi, 2 possibilities. 1. Same material which got merged with the same. 2.Check with fine mode.
i changed the material and its still not showing. I am in fine view, its not appearing in coarse or medium either. It does appear in all those settings on my elevations. That will Teach me for trying to be clever and save time instead of drawing it on every section and detail!?
Did you create that profile family with "invisibles Lines" or what?
![4 Stars: 19 Votes](/images/stars_4.gif) |
There is no reason why it should not display. It could be a number of things - have you checked the following: Turned off in VG Hidden in view In a workset that is turned off in the view In a design option that is turned off In a different phase
Are you using this profile as a wall sweep? If so check to see if it has 'cuttable' checked.
AHA it was the Phasing!!! always simple when you find out hey. Thanks all.
CUSTOM GUTTER PROFILE |
Wed, Mar 27, 2013 at 1:59:53 PM
Gutter display on roof plan |
Mon, Jun 11, 2007 at 3:47:21 PM
Anyone got an easy way to cap the end of a gutter sweep? Anyone? |
Wed, Feb 14, 2007 at 7:22:46 PM
Sections tag |
Mon, Apr 6, 2015 at 9:50:58 AM
Gutter but what about gutter downpipe? |
Mon, Feb 22, 2016 at 12:31:57 AM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
