35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> display of families in different views
Wed, Sep 2, 2009 at 9:35:56 AM | display of families in different views
eveline
Is it possible to have a different display of an object, for instance a cabinet, in different views?
I would like to show only the electrical fixtures an an outline of the cabinet in one plan-view and the actual cabinet and the text-label in an other plan view.
Different detail levels is not a solution here.
Eveline
Wed, Sep 2, 2009 at 1:05:45 PM | display of families in different views
3.5 Stars: 401 Votes
If you use sub-categories in the family, you could control this through VG.  The line work could be a sub-category turned off in non-model views and the model elements could be a different one.
Wed, Sep 2, 2009 at 4:10:52 PM | display of families in different views
eveline
Yes i tried that. The sub-category doesn't work for the electrical fixture wich is a nested family.
Wed, Sep 2, 2009 at 4:23:50 PM | display of families in different views
Now you add more to your question...What exactly do you want?  I will not guess again.
Wed, Sep 2, 2009 at 4:40:46 PM | display of families in different views
eveline
Thank you for answering, sorry I wasn't very clear.
An instance of an electrical fixture family is part of a furniture family. I think that is called a nested family. I want to be able to turn visibility of this element on and off on different plan-views.
I tried to put it in a sub-category but could not.
Question: Is there a way to put a nested family in a sub-category or is there an other way to control visibility?
Eveline
Wed, Sep 2, 2009 at 4:43:53 PM | display of families in different views
Annotations are controlled seperately in VG.  Turn it off there.
Fri, Oct 16, 2009 at 11:12:21 AM | display of families in different views
JFK64
eveline
You could try this approach:
In your nested Family creation (family Editor) highlight the Electric Fixture family then choose the Element Dialog box. In the Dialog box you'll see a line that says "Visible" to the furthest right there's a little gray box click it. At that point a box come up asking for a visibilty parameter. Go to the button that says Add Parameter, You are about to creat a Yes/No parameter for visibilty. Make sure it's an instance parameter (So that each occurance has this option indepently), catagory like Graphics and then a title like Electric Fixture On. OK out back to your nested family save, import that whole thing. When you use it in your project you can then highlight the desired Furniture family (we are talking about) and be able to make for fixture visible or not
John K
Fri, Oct 16, 2009 at 11:30:40 AM | display of families in different views
JFK ... This will change the visibility in every view...not what the poster asked.
Fri, Oct 16, 2009 at 2:46:47 PM | display of families in different views
JFK64
Views OOPS I'm BAD then. Yes Hub is correct.
Hub how about this then????....
I've had an situation where I wanted to see a family in one view (the drawings we give consultants) and our plotted view (where we don't want to show "said family". We are starting to use View Templates with that family as a Filter so as to turn it off in those certain views. That might work here too????
Mon, Oct 19, 2009 at 7:07:23 AM | display of families in different views
View templates are one of Revit's really powerful tools.  You should be assigning a view template to every view you want to control.  Then just before printing, you can highlite all the drawing sheets and select "apply defauly view template" and every view on every sheet will be correct as you have planned them....if eveyone follows the rules...
Mon, Oct 19, 2009 at 8:55:36 AM | display of families in different views
#11
JFK64
Hey Hub
I get your last post, so this is something related.
Under View Properties theres a line under Indenty Data that reads: "Default View Template"
What is that? And how is it suppose to work? I gave it a default view template once but it never automatically makes that "choosen" View Template anything special.
Can you explain it?
Thanks
John K
Mon, Oct 19, 2009 at 9:15:23 AM | display of families in different views
#12
In my opinion, this is mis-named.  For each view, the field "Default view template" should be named "Assigned view template".  Just assign the correct template her - then when you pick all the sheets and select apply default view template, the assigned view template will be applied to the view.
Fireplaces do not display in any views except 3D
Wed, Mar 16, 2005 at 1:16:02 PM
Symbolic Line Display in Door Families
Wed, Jul 25, 2007 at 9:24:08 AM
Grids at an Angle in Plan don't display in Elevation
Thu, Apr 26, 2012 at 2:44:38 PM
turning on/off nested families in host family in different views in project.
Fri, Aug 7, 2009 at 11:11:32 AM
Certain views display blank SOMETIMES
Fri, Oct 2, 2015 at 4:14:00 PM
Page generation time: 2.9850
