38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Programs for rendering
Wed, Sep 2, 2009 at 8:07:12 AM | Programs for rendering
neotropic
Hi,
 I have a  question regarding rendering.
 I would like to render around 40 - 50 revit drawings. All the drawings are separately. I tryied to render in revit, but it takes too long time.
I have read about max, viz and also about artlantis.
So my question would be, what program the users of revit would suggest?
Which way it would be faster to render all the drawings and also to but the drawings on a queue. So I could but the computer to render and I wouldnt have to be there.
 Regards,
Tom
Wed, Sep 2, 2009 at 4:09:46 PM | Programs for rendering
Thread Post Kudo! #2
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Your rendering time depends on you image size, resolution settings, etc. Did you try to render your model in medium/high settings? I barely use "Best" settings in Revit. If you want to multi task-render, you can do so by opening the same file using multiple-opened Revit applications. Obviously, this would open the file as read only, which is ok, if you're only planning to render a static image. Don't know how much experience you have rendering in Revit but it can render pretty decent Cryingquality and time) depending on your settings. On the other hand you can use 3Ds Max.
HTH
 "If you tell the truth, you don't have to remember anything"
Tue, Sep 15, 2009 at 2:32:58 AM | Programs for rendering
neotropic
Right now I used revit itself to render the images. But further on, I'm planning to use 3ds max instead.
But thank you very much for the information.
Rendering Programs for Revit
Fri, Apr 17, 2009 at 4:30:35 AM
Concerning Revit and other rendering programs
Sun, Jul 26, 2009 at 10:15:42 PM
Rendering in 2009
Wed, Jun 11, 2008 at 3:18:08 PM
High Res Textures for Rendering
Fri, Apr 17, 2009 at 12:15:29 PM
PDF programs
Thu, Jan 29, 2015 at 12:41:33 PM
Page generation time: 0.8324
