72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Export Schedule into PDF format
Wed, Sep 2, 2009 at 7:10:33 AM | Export Schedule into PDF format
Rams
3 Stars: 3 Votes
Is it possible to export schedule directly into PDF format?
One way is to drag the schedule view into sheet and then generate PDF but i want to export it directly from schedule.
Please suggest something
Now on the implementation stage....
Wed, Sep 2, 2009 at 12:08:18 PM | Export Schedule into PDF format
No.  A schedule is not visually formatted, you must place it in a view then PRINT to a pdf.  PDF's are not exported because they are just an image.
Printing files to PDF format in Revit 2008 Building
Fri, May 30, 2008 at 1:03:04 PM
3d Export Format
Thu, Nov 30, 2006 at 4:25:34 PM
Plotting to PDF format
Thu, Jan 21, 2016 at 3:08:26 PM
Export a 3D veiw to pdf
Tue, Sep 13, 2011 at 9:10:53 PM
13
Schedule format
Mon, Mar 5, 2012 at 2:33:50 PM
Page generation time: 15.1336
