59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Schedule Count Parameter
Tue, Sep 1, 2009 at 3:10:52 PM | Schedule Count Parameter
loftus
So - I am working on an equipment schedule, and the client would like it to have one piece of equipment - a range lets say per line, and the count parameter to number how many are in the project.
 I don't know if this is really obvious and I'm just missing it - but how can I creat a schedule with each type of equipment listed once and the count to cover how many are located within the project.
thanks to any help.
Wed, Sep 2, 2009 at 6:40:20 AM | Schedule Count Parameter
nafenn
Open the schedules properties.
Go to the "sorting" tab and sort by type also make sure the "itemize every instance" box is NOT ticked.
This should help.The best way to realy understand schedules is to just try different things try turning the options on and off and see how it effects the schedule, you should work things out pretty quickly.
Wed, Sep 2, 2009 at 11:02:10 AM | Schedule Count Parameter
loftus
Eureka! Thank you so much for that insight - like I said so obvious.
COUNT Parameter in formulas: a workaround
Thu, Apr 10, 2014 at 6:40:32 AM
ROOM COUNT SCHEDULE
Tue, Aug 22, 2006 at 2:45:49 PM
Schedule - Count Error
Wed, Sep 16, 2009 at 7:12:41 AM
Schedule Count as Percent of Grand
Thu, Dec 22, 2011 at 10:33:17 AM
window schedule by mark and count
Wed, Jun 4, 2014 at 2:31:52 PM
Page generation time: 1.2837
