34 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> color scheme question RAC2009
Tue, Sep 1, 2009 at 10:15:27 AM | color scheme question RAC2009
sfountain
I'm attempting to produce a plan that has areas defined by the 'type' of work being done (renovated areas, new construction areas, areas where no work will be done) What I would like to see is a color scheme that relates to those areas and gives the total square footage for each, meaning renovated areas are one color and the total square footage of those renovated areas is xxx. Ive managed to get close by using a color scheme and an area schedule, but I'd like to see something combined - a color scheme that shows "color equals total square footage." Ive also experimented with rooms and legends, but I just cant seem to produce a 'smart' graphic that shows a color and an area.
the pdf has two sheets i mocked up - one is an area plan, the other uses rooms scheduled by departments(i just named the departments according to the work to be done) both sheets have color schemes, and an area schedule....
is it possible to do what i'm looking for?
Tue, Sep 1, 2009 at 10:06:12 PM | color scheme question RAC2009
TomDorner
4.5 Stars: 25 Votes
See if my answer to this thread helps at all.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=17712
(sorry if hyper link doesn't work but this site through my Mac doesn't seem to give all the options)
Tom
www.reviteer.com   http://twitter.com/Reviteer
Wed, Sep 2, 2009 at 9:56:11 AM | color scheme question RAC2009
sfountain
thanks tom
i quickly went thru your instructions and tried the project paremeter method. i created a color scheme legend based on that parameter. in the color scheme i created values based on new construction, no work, and renovated work areas. im still not able to get the legend to show the total square footage of each area.
Im guessing the text paramter isnt adequate for this, so Im trying to quickly bone up on using formulas and such to see if that gets me anywhere...or have i missed something obvious in your instructions?
thanks again - obviously i need to spend some time on project / shared parameters!
Wed, Sep 2, 2009 at 10:56:52 AM | color scheme question RAC2009
TomDorner
4.5 Stars: 25 Votes
The legend will not show the square footage.  Do a schedule of the areas and sort/group by your new parameter and add the grand total.
Then place your view with the color legend on a sheet and add your schedule to the same sheet.  You can position the schedule right below the color fill to support the color fill information.
HTH
Tom
Wed, Sep 2, 2009 at 11:11:50 AM | color scheme question RAC2009
sfountain
heh heh heh...thats how i did it before posting (see the pdf's in original post)
'preciate it though...
RAC2009 - color schemes don't show up
Mon, Jun 24, 2013 at 9:04:35 AM
color scheme disappear
Fri, Sep 24, 2010 at 7:49:22 PM
new color scheme entry error
Thu, Sep 18, 2014 at 1:42:54 PM
12
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:38 AM
Color Scheme Problems
Tue, Jun 26, 2007 at 11:53:16 PM
Page generation time: 3.4432
