79 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> lineweight problems
Tue, Sep 1, 2009 at 1:50:24 AM | lineweight problems
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
Revit 2009
 I have attached ground and first floor of building I'm working on, and as you can see lineweight of external wall at ground floor is thicker than line of the same wall at first floor. Anyone knows whay is this happening?
Tue, Sep 1, 2009 at 7:00:54 AM | lineweight problems
Are you sure it is your wall lines?  Do you have a slab edge, site pad or something else in the same position.  Tab over the line and see what all you find.
Tue, Sep 1, 2009 at 1:45:00 PM | lineweight problems
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Any chance you've got a foundation wall you're looking at, with a different cut lineweight?  Also, things like cove base can muddy up a drawing like that, where there's just not room to print them seperately.
Tue, Sep 1, 2009 at 11:09:46 PM | lineweight problems
qabulin
qabulin Avatar
You say you "attached ground and first"....
Can you expound on this and maybe look into it further?
 It almost looks like the plan on the left has a cut plane view through the wall, whereas the one on the right appears that its viewing the top of a wall.
Just a thought.  Hope it helps....
qab
^_^
Debian + VirtualBox + Revit
Tue, Sep 1, 2009 at 11:44:18 PM | lineweight problems
stankovic
stankovic Avatar
4.5 Stars: 7 Votes
Hub, yes it is a wall line, there was no floor or anything else below and I have also tried to copy this wall from ground floor to first floor level but same thing happened, wall line thickness is different.
AlterEgo, would it be possible to change cut lineweight of walls on each floor?
Qabulin, I meant PDF attachment to my post, sorry.
Thanks guys
Lineweight on Surface Patterns?
Mon, Jun 15, 2009 at 11:54:53 AM
Lineweight in perspecives
Wed, Sep 18, 2013 at 12:27:43 AM
Lineweight Problem
Tue, Jan 19, 2016 at 2:26:32 PM
Electrical Fixtures Lineweight
Tue, Jul 21, 2015 at 12:39:01 PM
Linked Cad - Global Lineweight
Wed, Sep 2, 2015 at 4:54:04 PM
Page generation time: 7.1768
