80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Printing Issue 2010
Mon, Aug 31, 2009 at 9:44:18 PM | Printing Issue 2010
Erik
I am putting one toe into the 2010 water, having read about crash issues.  Still using 2009, but a couple of smaller project in 2010 to test if I will have any problem.  So far no crash issues.
I do have however one issue, I need some help with;  In 2009, I 'publish to DWF' In 2010, I can export to DWF.  All is normal, but when I open the files in Design Reviewer (latest version) the thumbnails looks fine, but the preview pane is all scrambled and so is the print out.  I can print directly to any of our printers, and I am reluctant to go via a DWF Writer when the feature should be built in.
Any comments, similar experience or suggestions ?
Enjoy
Mon, Aug 31, 2009 at 11:07:02 PM | Printing Issue 2010
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
2D & 3D DWFx functionality in 2010 has been working fine for me since beta.  What settings are you using?
Regards,
Chris.
Wed, Sep 2, 2009 at 2:50:20 AM | Printing Issue 2010
Erik
Thanks Spot for your attention.
The problem comes in ADReview.
I am looking at all the settings for xporting to DWF and there are not many option.
I set up the printer (default= Revit DWF Exporter).  Printer selection just for size of paper/scale/what to include.
I try DWF and DWFx. All the same.  In ADR, thumbnails are as expected, but preview is scrambled as the print will be.
I can print normally directly to any of our printers from Revit
In 2009 all is fine.  I can not update till I have solved this problem
Revit 2010 Printing Problems [ 1 2 ]
Wed, Jun 24, 2009 at 11:21:32 AM
16
Revit 2010 printing random lines
Mon, Jan 4, 2010 at 10:51:10 AM
Printing changes annotations on sheets
Thu, Sep 15, 2016 at 6:55:42 AM
Printing issue
Wed, Jul 12, 2006 at 1:12:22 AM
Scope boxes printing, set not to print.
Tue, Feb 15, 2011 at 6:39:50 PM
Page generation time: 1.2005
