Forums >> General Discussion >> Wishlist >> Select all instances by view
36 Posts No Rating |
*sigh* I know there's a filter, and I do use it. But sometimes I need to just select all the 2x6 joists on a particular level to change them to 4x6 joists without changing the 2x4 joists also. unless I am completely missing something (and please tell me if I am!!) filtering only filters it down to a Structural Framing (Joists) option, which still leaves me with every size of framing that is defined as a joist. Select all instances by view.... it would be sweet.
98 Posts No Rating |
I completely agree. Sometimes it makes so much more sense to select all instances in particular views. Really bugs me that you can't do it easily.
Ah ... but you can with a couple of steps. Select all instances ... then isolate elements... then window the view and you have them all in that view only.
Good advice. That works, but there's something to be said for the convenience of something taking only one step. And it seems to me that a "Select All Instances In View" command would not be too difficult to create when "Select All Instances" already exisits.
WW, i agree, that is one way.... however, sometimes you still want to see what's around ~ or maybe i just like to be difficult ~ J
This will be available on the 2011 Release...
this makes me very happy (smiley intended!)
Edited on: Mon, Apr 26, 2010 at 7:12:15 PM
Find objects in views using "Select All Instances in View" |
Tue, Sep 3, 2024 at 5:10:21 AM
select all instances?? |
Fri, Feb 6, 2009 at 7:36:04 AM
Select All Instances does not actually show all instances |
Thu, Mar 28, 2013 at 1:38:37 PM
Select all of one linetype in a view? |
Tue, Jan 10, 2012 at 3:31:14 PM
SELECT ALL INSTANCES |
Fri, Jun 6, 2008 at 10:54:52 AM
Members: | 2106013 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
