140 Users Online (139 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Flip Control
Thu, Aug 11, 2005 at 4:13:35 PM | Flip Control
david5555
How do you use the flip controls w/in the family editor? I can place them, but they are never assocaited w/ anything.
Thu, Aug 11, 2005 at 5:25:12 PM | RE: Flip Control
TomDorner
4.5 Stars: 25 Votes
You need to have meaningful reference planes defined for them to work. To flip L-R you need a reference plane defined for "Center (Left/Right)" To flip front to back = "Center (Front/Back)" These are found in the reference line properties in the family under "Is reference" Also make sure that the define origin box is checked (ticked) so Revit knows this is the flip point for the family. HTH Tom
Thu, Aug 11, 2005 at 5:29:25 PM | RE: Flip Control
david5555
Thanks Tom, hta helps so much. There was nothing about that in the help file. (that I found) Happy Reviting.
Thu, Aug 11, 2005 at 7:11:43 PM | RE: Flip Control
TomDorner
4.5 Stars: 25 Votes
The help Revit file can be a little assuming and leave important stuff out. That is why forums like this are invaluable right now. Until all of this "tribal knowledge" get well documented into any easy to read clear and consise manual, Revit is going to face an uphill battle when it comes to massive sales IMHO. Revit is a great program, but I worry that it will wither on the vine unless this issue is addressed. Just because something is great and wonderful does not mean that it will see mass adoption in the marketplace (Beta tapes come to mind). Tom
Adding a Flip Control
Mon, Dec 5, 2011 at 5:12:52 AM
Flip Control
Wed, Mar 10, 2010 at 9:22:54 AM
flip control
Thu, May 31, 2007 at 5:13:56 PM
flip control only door panel & not frame/trim revit 2015
Mon, Apr 27, 2015 at 10:19:20 AM
Flip Control on Profiles
Mon, Jul 9, 2018 at 9:25:15 PM
Page generation time: 0.2795
