Forums >> Revit Building >> Technical Support >> Roof tags
Hi all, do roof-tags excist? want automatically to note the layering of the roof in a tagg Cee
Obviously you did not look in your library because roof tags are there. No tag can be created that automatically reads what layers are in an element. If you want that in the tag, you have to build it into parameters and assign labels in the tag to read those.
Example?
You need to create the example, not me. I am satisfied with the roof tag.
Ok, thanxs, imagine a roof with 5 layers, each layername a label tag thats what you say, and a roof tag with the labels that read the layers, hmmm,I will check it, but it is probably not interactive, and thats what I don't like, Imagine I change the structure layer form a 6" to 8" wooden beams tructure then a have tot change the label and the roof tag! anoying, But i will try and see what i can do. Cee p.s. labels cannot read the layer "names" i assume?
Roof Type Tags |
Wed, Jan 3, 2007 at 3:59:12 PM
Roof Tag where art thou |
Thu, Aug 30, 2012 at 1:25:23 PM
Roof Tags |
Tue, Apr 27, 2010 at 10:30:20 AM
Tags in Truss |
Mon, Jun 23, 2008 at 1:07:01 PM
how to create a roof tag? /revit2008/ |
Thu, Sep 16, 2010 at 10:53:25 PM
Members: | 2116454 | Objects: | 23196 | Forum Posts: | 152303 | Job Listings: | 3 |
