Forums >> General Discussion >> Revit Project Management >> Line styles won't appear in Perspective view
5 Posts No Rating |
I have an exploded model for some timber frame construction, however one view is an axon, the other is a perspective, i have model lines connecting the member locations. the axon displays model line style properly but the perspective doesn't, it does have line weights displayed properly. I am having to split the lines in the model and drag the ends of the segments apart to achieve the dashed effect, i was just wondering if there was a setting im missing, see attached views, any thoughts?
split lines... exploded models... this sounds rough!  can you explain a little better what your end goal is, and why you had to depend on exploding something in Revit?
qab
^_^
Debian + VirtualBox + Revit
Have you tried using the 'Linework' tool? I have found that useful in 3D views to hide lines I did not want to show. This can also be used to show lines as "Hidden" as well.
5 Posts No Rating |
Yeah, i did try that and i've come to the conclusion that aparently line styles don't apply to perspective views because line styles are based on a scale and the perspectives obviously don't carry scales . . . it makes sense, but it could be useful otherwise . . .
Workaround is to draw those connection lines on the actual sheet itself as detail lines...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
Adding line styles to Revit's Default styles |
Mon, Apr 26, 2010 at 11:29:51 AM
Perspective line weight |
Sun, May 3, 2009 at 9:53:36 AM
Ramp won't show cut in plan view... |
Mon, Mar 3, 2008 at 4:19:05 PM
Scaling a perspective view |
Thu, Sep 15, 2005 at 1:52:08 PM
Removing Line Styles |
Mon, May 8, 2017 at 2:21:05 PM
Members: | 2100884 | Objects: | 23171 | Forum Posts: | 152296 | Job Listings: | 3 |
