86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Consultants Model
Fri, Aug 28, 2009 at 10:12:23 AM | Consultants Model
emmettking
I am using Revit Archiutcture 2009: i have a MEPFP consultants model linked into my model.  I go to visibility graphics and turn their linked model to custom and i go into their model categories and try to turn off certain model cateogries and they will not turn off in my model.  What is the problem?
Fri, Aug 28, 2009 at 10:31:30 AM | Consultants Model
blake
3 Stars: 2 Votes
They could have drawn them under a different category.  Did you expand to show all categories?
Fri, Aug 28, 2009 at 10:37:57 AM | Consultants Model
emmettking
Yes, i epxanded and i have nearly every category hidden.  I have hidden the major portion of the category not the sub categories under the major categories.  Would that be the problem.
Fri, Aug 28, 2009 at 10:42:38 AM | Consultants Model
blake
3 Stars: 2 Votes
Shouldn't be.  What elements are you trying to hide?  You may try turning it off custom and seeing if you can control it through your model category first.
Fri, Aug 28, 2009 at 10:48:16 AM | Consultants Model
emmettking
I am trying to hide everyhting like ductwork and diffusers and piping conncetions and stuff like that.  I really just want to use their sprinkler head layout in my reflected ceiling plan.
Fri, Aug 28, 2009 at 10:52:05 AM | Consultants Model
blake
3 Stars: 2 Votes
Perhaps they have a sprinkler plan view set up that you can set to linked view then hide all the views annotation.
Fri, Aug 28, 2009 at 11:14:00 AM | Consultants Model
emmettking
Blake,
Thanks very much for the tip.  That worked and i was able to hide a couple of the other things i did not wnat.  For anyone else following this thread this is what i did.  Went to visibilty graphics set the linked model to custom and went to the basics of that model and selected fire protection under the linked views of ym consultant.  Then I customized the linked view further by turning off and on model categories and annotations specific to the linked model.
Limit Revit Access to certain consultants within Collaboration for Revit
Fri, Jun 1, 2018 at 2:50:05 PM
REVIT ARCHITECTURE MODEL TO CONSULTANTS [ 1 2 ]
Fri, Jun 10, 2011 at 7:08:23 PM
17
Working with Consultants
Tue, Sep 28, 2010 at 9:29:57 PM
Finding Consultants who use Revit
Thu, Mar 10, 2016 at 1:45:54 PM
Work with Consultants Workflow
Sun, Jan 28, 2018 at 6:03:06 PM
Page generation time: 1.6507
