103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> Structural beam won't show in elevation
I have a structural beam that will show in section view but in elevation view only the centerline of the beam shows. Stange because all other beams show fine in elevation. I've checked all the settings and can't figure this one out. I've tried redrawing the beam with no luck.
Post edited on 2005-08-11 15:59:50
16 Posts No Rating |
Have you checked your coarse/medium/fine viewport and family display settings?
This is default display for structural elements set to coase. Change to medium or fine to show the actual model.
That did it, thenks.
Wall won't show in North elevation |
Thu, Oct 9, 2014 at 12:21:15 PM
Elevation won't show in preview and can't be printed out |
Fri, Nov 20, 2015 at 10:58:59 AM
structural beam system visibility |
Fri, Jun 27, 2008 at 12:24:51 PM
blue triangle grips won't show on beam select - |
Fri, Jul 9, 2010 at 8:54:46 PM
Beam & Beam systems |
Tue, Oct 21, 2008 at 4:36:54 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
