Forums >> Revit Building >> Technical Support >> alt keycodes not working in 2010
6 Posts No Rating |
I am new to Revit Architecture 2010. I was always able to use the windows Alt keycodes in my text boxes. Now in any project that is in 2010, I am getting really strange chinese symbols or box symbols instead of the degree and diameter symbols?? Anyone have any reasoning to this??
Did you check the "Font"?
6 Posts No Rating |
yes, and all looks to be the same as used in 2009?
What is the font you are using in 2009? also in 2010?
6 Posts No Rating |
'Arial' for both.
Wierd, are you sure? because that's the font i just test in the both (2009/2010) and it work fine, same characters...
6 Posts No Rating |
Yea, I'm sure we've never used any other font?? I even checked using the keycodes thru other programs, just in case it was my computer, but they all worked fine too? Things like this are so frustrating?
![4 Stars: 19 Votes](/images/stars_4.gif) |
I found that happening also, but after starting Revit again it worked fine.
I just tried with other font and works fine ICE...
6 Posts No Rating |
tim123 - Weird? It did work after re-starting Revit? Thanks for the help!
This is a known bug, ensure you have the latest update installed.
Regards,
Chris.
alt codes |
Sat, Jul 11, 2009 at 11:26:39 AM
Shortcuts for symbols |
Sat, Jul 7, 2007 at 3:16:10 PM
The "Alt" key |
Mon, Sep 21, 2009 at 5:25:25 AM
Text Symbol Hot keys (ALT+......) |
Tue, Jul 6, 2010 at 11:59:49 AM
Superscript/subscript/degree text symbols in Revit |
Mon, May 9, 2005 at 6:08:59 PM
Members: | 2022385 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
